M6 crossmember
M6 crossmember
Has anyone ever used this Yank crossmember for an M6 before? I would like to take the stock mount off and use this one. Mainly for servicing the trans and clutch. It should be a bit lighter but easy to remove the trans, torque arm and mount.
Yes. I have it. Want installed pics or something?
It fits great, looks better, and much stronger!
In fact, since it interchanges with the TH400 you can go from a roadracing setup to a dragsetup in just a couple of hours if you know what you are doing.
Moving the trans mount off the trans is a huge advantage, also.
Took some pics [attached]. My digi cam doesn't focus anymore. But, I have had a TH400 and T56 in my car with this crossmember. Stock t arm aftermarket t arm... stock exhaust aftermarket exhaust. No clearance issues and makes the car look better on the underside. Excuse the dirty car. This is the first time I have driven it in about 3.5 months.
