***ATTN: SPEC*** Pics of my Stage 3
Old 07-11-2007, 04:55 PM
Bad Blue WS6's Avatar
I love mine,,hooks like a freak!!!
Most folks are quick to blame the Co,,when its usually the installer, or driving methods that screw them up. Not saying that is your case,,but I've had my Spec 3 for quite a while,,installed by Nasty Performance,,,,other than some chatter when cold, when i first take off in the morning,,its golden. And i am not gentle with my clutch sometimes.
BTW,,i think most clutch parts are made by the same folks.
Old 07-11-2007, 05:15 PM
brad8266's Avatar
Originally Posted by gun5l1ng3r
I don't think that there is one SUPER reliable clutch. It seems all the companys have had problems...
I don't even think that money can solve this problem of RELIABLE high HP clutches for the LSx motors...
Thats why the big power makers switch to Th400's
Old 07-11-2007, 05:59 PM
Sprayed1998's Avatar
How do I measure the disk.
Old 07-11-2007, 06:39 PM
kcmags's Avatar
I,ve got around 9000 miles & 100+ passes on mine. Procharged Zo6 ..runs 10.80s. NO PROBLEMS!!!!!
Old 07-11-2007, 06:56 PM
LrngCrv's Avatar
One of my friends has the spec stage 3 puck on a 297 rwhp bolt-on hobby LT1. It runs him some good times and he had it for awhile, took it out not long ago and it looked fine after a lot of use. I run a spec 3+ on my 419rwhp DD. Gone 3k miles and haven't had a problem yet. Babied it pretty good on the break in which was pretty hard
I have heard a bit about the puck stage 3s going out fast but maybe it is because they are used in the wrong situations? I can't respond on the bad batch idea though because I have no info outside of the 2 that I know of in use.
Always sucks to have a clutch problem though...
Old 07-11-2007, 07:17 PM
brad8266's Avatar
You measure the disk width with a dial caliper.
Old 07-12-2007, 03:32 AM
ErikElvis's Avatar
I honestly believe the installers have A LOT to do with these things wearin out quick. And I mean any aftermarket high performance clutch. They seem to be much more finicky than stock stuff.
Old 07-12-2007, 06:13 AM
98SS2836's Avatar
People think it's the miles you have to get on the clutch for break in. If you drive it on the highway all those miles its going to be junk you have to slip and drive it in stop and go to get it to seat.
Old 07-12-2007, 06:49 AM
I drove mine for over 1,000 miles in almost nothing but city driving. I understand that Spec has made clutches that worked in the past. I am not here saying that every single Spec clutch is a POS, but for everybody to sit here and ignore the fact that there are new guys poping up EVERYDAY with damn near the exact same problem is just ignorant. We are talking about Stage 3's, not Stage 3+, not Stage 2, just the Stage 3. Anyhow I will see about getting it measured this weekend although looking at the pics you can clearly see the clutch is toast reguardless of how much "wear" there is. Seems like something you guys would do when I sent ot back to be "looked" at.
Old 07-12-2007, 07:01 AM
Jon5212's Avatar
I've heard these stories now about Ram clutches, Tex clutches, any aftermarket clutch. Its not just SPEC people, and I agree also i believe the inherent problem lies with installation/break in, and I believe the biggest part is Hydraulics. I personally have a Spec 3 in my DD over 6K miles on it now, not one problem and I do quite a bit of city driving... i just don't ride the crap out of it.
Old 07-12-2007, 07:25 AM
brad8266's Avatar
You make a good point. Its not just the SPEC units, there are lots of failures from all the different brands of clutches and the majority of failures I would chalk up to improper prep/install, bad breakin, and the driver thinking their performance clutches are supposed to be driven like a stock organic clutch. I hear a lot of talk about the stage 3 theat SPEC makes but I have yet to have any solid proof that the defect is in the product. Usually what i see is clutches that look like they had the **** slipped out of them and overheated.
Old 07-12-2007, 07:42 AM
  #32
Jon5212's Avatar
^^^ In my world I'd rather have a 400 dollar clutch go out instead of a 1000+ clutch IE Textralia. I plan on replacing my 3 with a 3+ sometime in the future and going to throw all new hydraulics in again when I replace it.
Old 07-12-2007, 09:08 AM
  #33
Man it is getting to the point where I am gonna have to do a list of every name on this site who has had problems with their stage 3's. I really don't want to because it would take a LOOONNNNGGGGG time. The clutch was broken in well for over 1,000 miles. It was installed by a well know shop who also happens to be a sponser of this site. And on top of that I have been driving standard mustangs/camaros for 7 years and have yet to have ANY clutch last less than 40k miles. What else do you need to hear to realize that I did nothing to provoke this POS clutch to wear down. I know alot of the time it can be the installer or the driver but it seems like some of you guys seem to think that every single clutch ever made is 100% perfect and god forbid if it wears out that it has anything to do with the clutch itself.
Old 07-12-2007, 09:18 AM
  #34
brad8266's Avatar
I know the amount of people that had bad experiences with stage3's, and I also know a bunch of people that have fine stage3's recently, so I doubt it is a bad batch issue like some think. I know a guy running a 600HP turbo Z06 that runs a stage 3 and its fine and it sees track time and a lot of street racing. Could there be bad clutches out there, yes, but most of the pics I have seen look like slippage/overheating and I have also have had people with these so called bad clutches tell me that when they installed them they did not torque the flywheel or pressure plate bolts to proper value, they just tightented them until they were tight, lol. Then some people reuse all the old *** stock hydro pieces instead of buying new hydros like they should. I have also seen a few where the stock flywheel was reused with the new clutch and was not resurfaced or balanced. My point is that many of these so called bad clutches have other reasons for failure and i am just hesitant to blame the clutch unless of course it has obvious damage such as rivets that came out.
Old 07-12-2007, 09:33 AM
  #35
I never denied that people did not have luck with stage 3's. That is part of the reason why I bought it in the 1st place. But I didn't, and it just so happens that at the same time mine failed there is about 20 other people with the same story. So call it what you want, but I sure as **** don't see the same amount of people complaining about the Tex, Mcloud, Ram, LS6, LS7, in fact I see slim to none, where on the otherhand it seems like someone is posting pics of their burnt up Spec3 on a daily basis. You can blame it on the installer, blame it on the driver, but if you wanna sit here and tell me that you don't find the sheer amount of spec 3's going bad lately a bit odd then you either work for the company or your ignorant, lol.
Old 07-12-2007, 09:43 AM
  #36
brad8266's Avatar
You are right I dont see as many of those other clutches failing, part of that might be that the SPEC 3 is like the most popular clutch out there, so obviously there will be more failures. If you sell lots of a product you will have more failures.
Obviously you havent read much about all the broke TEX's yet, plus the LS6/LS7 clutchs dont break as easily since thery are stock organic pieces which are very forgiving. I wouldnt even consider them performance clutches.
All i can go by are the pics that are posted of these so called **** clutches and I also go by what people tell me when i pry into their install/prep of the clutch. Most of the time I find faults somewhere.
What shop installed your clutch?
Heres what Ranger (one of the more respected clutch guys) says of the LS7 clutch.
Originally Posted by Ranger
Plenty of C6Z06 owners have been forced to replace the LS7 clutch.
If the car is launched, the LS7 clutch sucks. On the C6Z launch rpm can be no higher than 3600 or so, and the pedal release must be lightning fast because it will glaze with slight intentional slip at >2500.
It seems fine, however, if the car is never launched.
Ranger
So i guess the LS7 isnt even a great clutch if you plan of drag racing.
Old 07-12-2007, 09:50 AM
  #37
brad8266's Avatar
Iif you wanna sit here and tell me that you don't find the sheer amount of spec 3's going bad lately a bit odd then you either work for the company or your ignorant, lol.
The stage 3 failure thing isnt just a lately thing. And no i dont work for any performance company, I would hate to work in that business. As for me being ignorant, maybe so, you be the judge on that.
Old 07-12-2007, 01:46 PM
  #38
PAGregSS's Avatar
I've got 50K miles on my Spec 3. It's seen 150 shot of nitrous with no problems.
Old 07-12-2007, 01:53 PM
  #39
Dip Stick's Avatar
hehe still on my stock clutch original clutch
But have a ls7 sitting in my garage
Old 07-12-2007, 03:24 PM
  #40
brad8266's Avatar
Hell yeah, I ran my stocker with 465HP, the only reason i replaced it is cause I swapped motors, figured may as well replace the clutch while im at it.
Quick Reply: ***ATTN: SPEC*** Pics of my Stage 3
