RAM adjustable master cylinder
Old 07-14-2007, 01:48 PM
99TransAmLS16Spd's Avatar
Default RAM adjustable master cylinder
Just wanted to give some feedback on the piece as I was able to find little info using the search prior to purchasing...
Yes, it is a stock master modified in basically the same way as the DIY.
However, you need to grind down the bearing on the rod end!!! This is the only way you will be able to get the retaining clip back on. Do it before you install it. A good way to measure is simply pull the stock master first and measure off of that.
Just to note, the stock master cylinder was 90% of my issue of not being able to shift at high rpms and the pedal sticking to the floor. I had previously performed the drill mod as well as changed fluid/bled the system. I assume the stock master cylinder had went bad, but the adjustment is nice as well.
Quick Reply: RAM adjustable master cylinder
