LS7 Clutch kit Question Please help!
I was wondering if anyone knows What TO bearing I need for the LS7 clutch with with LS2 Flywheel. Also, Will My stock Slave Cylinder work with the TO bearing I need for this kit? Please any information I would be great.
I just replaced my slave and dont want to spend another $150+ for another slave if I dont have too.
LS1TECH & Trucks Sponsor
You'll use the same slave cylinder and TOB that your car was equipped with from the factory. If you've got alot of miles on yours or if you've got a pre-'01 F-body and haven't already, you might go ahead and swap the slave cylinder while you're there.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Originally Posted by 68birdls1
Thats what I went ahead and did when I put my ls7 clutch in
Originally Posted by PureWS6
Me too. My car had low miles but the slave/TO bearing were showing significant wear.
When I did my LS7 swap, I got a new slave, and the kit. Didn't get the master, but we did do the drill mod. I would have bought a new master if I had the money, but I was on a very tight budget you know.
As stated above your stock OEM stuff will work perfectly fine. I do suggest goin ahead with at least a new slave which has a TO bearing on it. Then just check the pilot bearing & if it's good to go put it all back together exactly like to disassembled it. Just like installing a stock clutch.
And for the record I'm on stock 99' master still & have had ZERO pedal issues at any RPM level. My stock hydrolics have about 103k on them also.
