Comparison of f-body to GTO t-56
Tough Mudder
Comparison of f-body to GTO t-56 CHART!
I was looking for a chart like this. There didn't seem to be one, so I created my own. Hope this helps someone.
If you find any errors, please let me know.
The way I see it....1st gear +.031 = 3.73 - 2nd gear +.029 = 3.71 - 3rd gear +.013 = 3.55 - 4th gear +.00 = 3.42 - 5th gear -.26 = 3.16 and 6th gear -.44 = 2.98. Although, I'm not sure if there is a direct correlation between increased tranny ratio and the differntial gear ratio.
You are speaking of overalll gear ratio.
The MN12 is better suited for N/A applications because of the lower 1st and 2nd gear ratios as the T56 is better suited for forced induction and higher powered setups . I would also say the the T56 gears should be stronger than the M12 ratio just on the ratios alone .
