Flywheel shim between crank and flywheel? what is the depth measurement for flywheel?
Hello everybody, does anybody know the depth of a stock LT1 flywheel? i purchaced a flywheel from autozone that was resurfaced and i dont know if i need to use a shim or not. it did not come with one. does anybody know the measurement of a new unsurfaced flywheel?
I have done many L1 clutch jobs and never had to shim the flywheel. I actully think it is a good thing for the flywheel to move slightly forward because it provides better fork clearance for some aftermarket clutches. Shimming the external LT1 slave does nadda, it is self adjusting.
