Just Installed new slave cylinder.. HELP!
Old 11-25-2007, 10:26 AM
CK9887's Avatar
Default Just Installed new slave cylinder.. HELP!
Well after all day of working in the wet and cold in my driveway we finally got a new slave cylinder in my car...
Well we get everything back together and bleed the system but it feels like there is no clutch there. We bled the system probably 3 times and the clutch pedal still never tightens up.
What can we do?
Old 11-25-2007, 12:04 PM
blue98Z's Avatar
Check the connection at the slave cylinder ( they can be a bitch sometimes ) and make sure the bleeder valve is fully closed if you haven't already done that. Sometimes it takes a little while to bleed these systems the old fashioned way. I think we had to do mine about 5 or 6 times before it got to where it felt good. Goodluck fixing it.
Old 11-25-2007, 12:56 PM
CK9887's Avatar
Ya not a whole lot of fluid was bleeding thru so im guessing theres lots of air in the system and its taking a while to fill up the new slave.
Im hoping the issue is as simple as bleeding it.
The quick disconnect line that hooks into the slave cylinder was a bitch to get off the old slave but we finally got it off
Old 11-25-2007, 01:01 PM
blue98Z's Avatar
Just make sure while your bleeding it you keep the reservoir full cause mine would suck it out pretty fast.
Old 11-25-2007, 01:12 PM
CK9887's Avatar
Thats whats weird, its really not sucking that much thru the reservoir. Only a little bit of fluid is coming out when we bleed it.
