Question On Spec 3 + Clutch Please Help
I just bought a new spec 3 + clutch with pressure plate all new for a good price on ebay. But it does not come with the clutch alignment tool or the throw out bearing . The guys says i can just buy these parts at a local part store for cheap is he right and is that all i need to replace my clutch. what about a shim ? thanks
My spec came with a shim so I used it. You can get a clutch alignment tool anywhere. Actually if you want I have an extra clutch alignment tool and a brand new throwout bearing that came with my clutch that I don't need because I bought a new slave and it came with a throwout bearing on it. I will sell it to you for $45 shipped, it's like $65 from GM.
SPEC can send you the shim you need, its like .100 inch I believe. The alignment tool can be had from a local store and you dont need a new TO bearing you can juts use the one you have although i would highly suggest buyin a new slave cylinder while you do the clutch job. The slave comes with the TO bearing too.
I have a TO bearing, alignment tool, shim, and pilot bearing I can sell you though if you want. Pm me if you are interested.
definitely don't reuse the throwout bearing, especially if you have a lot of miles because later down the road if you didn't change it, there's a good chance it will fail and as result it will destroy the fingers on your pressure plate when it lets go.
