Which one
Old 01-30-2008, 07:21 PM
Iron Head's Avatar
Default Which Master on OZ700?
What master cylinder are you OZ700 guys using? Tex says gm,installer says Ram adjustable. I bought the stock one but I don't want the disengagement issues i've heard about. Advise appreciated.
Old 01-30-2008, 07:36 PM
Likestogofast's Avatar
The stock unit will work fine. I had to make mine into an adjustable unit to get it to disengage properly but now it works great.
Old 01-31-2008, 12:28 PM
Iron Head's Avatar
Will the stock master cause disengagement issues with this clutch or should I just buy an adjustable?
Old 01-31-2008, 12:36 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I have a 40K GM STOCK
No enagement issues, engagement higher then stock by far.
You will be fine.
Had the clutch master been old, or alot of miles, you could throw a RAM in there but its more or less stock, just an adjustible rod...
Old 01-31-2008, 12:47 PM
When I installed my clutch I was still running the stock master cylinder with 70k on it. I could drive around normally with no shifting issues whatsoever, but when I tried to shift at high rpm's it would not let me. I called Textralia and they recommended I follow the sticky on how to make the stock unit adjustable. I bought a new one and did the conversion and problem solved. I was informed that the stock unit normally will not cause any trouble.
