Which bolts? 13mm/15mm
Old 03-12-2008, 12:24 AM
ss1le02's Avatar
Default Which bolts? 13mm/15mm
The bolts to mate the tranny to the bell housing and the bell housing to the engine are the same thread size. Each requires 8 bolts. Which takes the 13mm head, and which takes the 15mm head? I think the 15mm head bolts are for the tranny/bell housing and the 13mm head bolts are for the bellhousing/engine. Am I right. I pulled it all apart a few days ago and can't remember. I'm having a senior moment.
Old 03-12-2008, 09:01 AM
98whiteFormula's Avatar
those bolts are completely different.the tranny/bell housing bolts are black and threaded all the way.while the bellhousing/engine are dull colored and are not threaded all the way.you should still have the bracket in one of your tranny bolts,unless you took that one out to.
Old 03-12-2008, 11:03 PM
ss1le02's Avatar
you are right. I was wondering where that 8th bolt was. It's still on the vent line bracket for the tranny.
