I think I figured out the problem. What do you guys think?
I've been having problems shifting my car quick. The problem has been getting worse. When I'm at high RPMs shifting through the gears, it feels like there is a wall between the gears. It used to just flick between gears very quickly. Now there is a delay. When I had the tranny out to fix the fork, I put in a new LS7 clutch. I didn't replace the slave, throwout bearing, or pilot bearing. That was about two years ago. I tried replacing the clutch master cylinder. No change, so I resigned myself to pulling the tranny. I thought maybe something was wrong with the clutch system. When I was pulling the tranny out, needle bearings started to drop out. The pilot bearing is bad.
So my question is. I know that it is bad to have a junk pilot bearing, but is it enough to give me the problems I'm having shifting?
Bleed Your Hydros Completely, Get A New Slave ($100 From Sdpc)
Wrap The Line With Exhaust Tape And Do The Drill Mod. If It Feels Like A Wall Then It Is Probably Not Gonna Be The Pilot That Is Causing The Issue, Just Coincidence Imo
im not saying its impossible, im sayin its probable
it just sounds like a hydro problem. when is the last time you bled the system?
whats the story on your trans? has it ever been rebuilt?
