Spec clutch discs
Spec clutch discs
Does anyone know where I can get just the clutch disc for a SPEC stage 3? I need to replace the disc and have the flywheel resurfaced, but I dont want to have to buy the whole kit. Is there anywhere that I can just buy the disc? and if so, will a stage 3+ fit on a stage 3 pp??
Good question. I'm having mine pulled right now due to oil saturation on the clutch. Turns out, the GM dealer that put my spec 3+ clutch in actually bent the freeze plug on the crank shaft, so oil has slowly slipped it's way in and eventually ruined the clutch. If i can just get the disc replaced and resurface the flywheel, i'll have an extra clutch on my hands!!!
