Still no 5th,6th or rev
Old 04-26-2008, 11:21 AM
zlicious94's Avatar
Default Still no 5th,6th or rev
Hey guys so I just had my ram hd put in and now Im locked out of 5,6,and rev? Everyone said just bleed the clutch,so I did really well,and still locked out
wtf? Even the 1st thru 4th doesnt feel as smooth as it should too?
Old 04-26-2008, 11:49 AM
delsold's Avatar
something you might want to check if you have an aftermarket shifter with stop bolts is the front stop bolt. when e toi worked on my clutch the vibrations loosened the stop bolt and it backed in toward the shifter, and i got locked out of the tops gears. This was with a Pro 5.0. Worth a check if you have stop bolts!
Old 04-26-2008, 02:39 PM
Cap'n Pete's Avatar
LS1Tech 10 Year
Sounds like it could be a problem inside the tranny?! 5th/6th & Rev are all contained in the tail section of the T56, while 1st-4th are in the main body of the tranny. I wonder if it's a problem with one of the shifter rails that operates those gears???
Old 04-26-2008, 05:54 PM
zlicious94's Avatar
I do have a pro 5.0, but before the new clutch it went into gear just fine? Thats why I dont beleive its a trans prob.A shop told me that my clutch wasnt installed right?
Old 04-26-2008, 10:05 PM
delsold's Avatar
Ha if you have a pro 5.0 i'd recommend taking the 2 seconds to pop the center console out and check out that top stop bolt. Mine shifted fine, stopped the car, went to start it back up some time later, and no 1st or 3rd. Drove it around thinking something went bad with the clutch hydraulics or tranny, and the next time i stopped and started it, i didnt have 3rd, 5th, or reverse.
Old 04-26-2008, 10:07 PM
delsold's Avatar
And sorry about my first post, i just re-read that and I had just woken up from a night or a little partying....my bad for the gramatical errors!
Old 04-26-2008, 11:11 PM
zlicious94's Avatar
I dont think its the stop bolt because if im driving it will go into all gears but at a dead stop at idle it wont go into rev or 5th or 6th so?
Old 04-26-2008, 11:49 PM
LT1_Fireman's Avatar
I had the very same problem after installing a ram hd also .All I did was change the slave and drove it a little and they loosened up on there own.
Old 04-27-2008, 06:43 AM
LS1Tech Sponsor
Slowhawk's Avatar
Sounds like a shifter or the reverse lockout solinoid.
Old 04-28-2008, 08:15 PM
zlicious94's Avatar
Well I guess im gonna do a new slave and master this week too see if that is it?? Solenoid checked out fine?
