Wot Shifting Problem
I have a 98 z 6speed with twin disc clutch, adj.slave cylinder, and b&m shifter. When driving normal(not beating **** out of it) the trans shifter perfect and even when mildly on it but when wide open it doesnt want to go from any one gear to another with out some delay. It seems to me that it is usually when the rpm comes down a bit that i can finally get the next gear. any sugg. or idea would be appreciated...?????
I had the same problem recently with my Spec 3+. The clutch is probably not fully disengaging. I ended up having to put a different clutch in the car even though I have an adjustable master.
