t56 rated to ?
Old 07-27-2008, 01:55 PM
suprat04r's Avatar
Default t56 rated to ?
stock, what's the T56 tranny rated to hold, HP and Torque wise?
to hold up reliably to 600whp, would you need to have it rebuilt?
Old 07-27-2008, 01:59 PM
52172's Avatar
yes. I believe stock they are only rated to about 500lbs of torque.
Old 07-27-2008, 03:02 PM
gnx7's Avatar
Use the search buttom rookie.
Stock torque rating is around 500ft/lbs I believe.
With upgraded steel shift forks, carbon blockers, and synchros an otherwise stock T56 in a 3500lb Fbody can handle 700rwhp/700rwtq. Beyond that you want a Viper output shaft and potentially other parts for reliability. There are a few vendors on here that can build you one. Costs around $1K to have one (you supply) built.
A few people have run 1000rwhp thru a stock T56 and upgraded clutch on the dyno... will it do it.... yes... with any form of traction in the real world environment will it last.... absolutely not.
Old 07-28-2008, 04:00 PM
blk00ss's Avatar
My car makes 650hp/730tq and I have a stock t56 with a spec 3+ and stck adj. master cylinder. And so far I have put around 3k miles on it with no hic-ups so far. I know it wont last long, just saying its possible. Thats with MANY street runs, and probably 20+ track passes. BTW the transmission come from a car with 120K miles on it.
Quick Reply: t56 rated to ?
