question on quick disconnect
Old 08-11-2008, 11:05 AM
gss9909's Avatar
Default question on quick disconnect
For some reason I can not get the quick disconnect to stay in the slave cylinder. every time I press the clutch in it pops out just enough to disconnect.
I undid the bleeder valve to let out pressure and then connected it. Still did not work.
Old 08-11-2008, 02:33 PM
crainholio's Avatar
Lube the o-ring on the connector with clean brake fluid and re-test.
Old 08-11-2008, 03:50 PM
gss9909's Avatar
ok iI'll try it. Can't hurt. thanks
