Cant wait to do the drill mod!
I just got my car less than a month ago. I went to the track twice with it & ran shitty times. Mid to low 14s then low 14s to high 13s. Part of it was getting used to shifting the T56 at the track. The other problem I ran into was anytime I tried to do a 3000 rpm launch the car wouldnt shift. If I left from an idle, it shifted better. I did miss 3rd a few times the first time I went, that was with the shitty Hurst rubber bushing shifter handle. I do have a pro 5.0 shifter on the way, but after reading about this drill mod, it appears this may be the problem.
i'm about to do the drill mod. i've got an adustable master to install while i'm at it. just curious, you said it wouldn't shift when you were trying to launch? you mean it wouldn't shift into second after you launched?
