Clutch Chatter
Old 08-27-2008, 06:17 PM
99ws9's Avatar
Default Clutch Chatter
I recently installed a spec stage one clutch in my 99 ta and I have a LOT of chatter. Not only does it chatter bad in reverse and on takeoff but it also chatters bad on downshifts. I've only put around 250 miles on it and I know that its not good and broken in yet. I was just wondering the best way to break it in. I've read about people going easy on them for 3000 miles and still experiecing chatter. Any help would be greatly appeciated.
Old 08-30-2008, 02:47 AM
matt_ls1_z28's Avatar
i am currently having problems with my clutch pedal sticking to the floor when i hammer down on it...and when im sittin at a light i hear a slight chatter...so i put dot 4 brake fluid in it and its stopped the chatter and slightly helped the pedal problem untill i put few miles on the new fluid...but try that i hope it works
Old 08-30-2008, 07:25 AM
DaddySS's Avatar
Did you carefully torque the clutch down in a star pattern with 3 passes - 1/3, 2/3 then full torque?
Was the flywheel new?
Was the disc clean?
Old 08-30-2008, 12:56 PM
LS1crazy01's Avatar
If you have the stock gear you can expect more chatter then if you had a different gear in it. My RAM did it and it stopped 90% after 500 miles. During the life of that clutch it still did it now and again depending on how much clutch and throttle I was using. I have also heard this happening bad for the entire life of some spec clutches as well though. Good luck I hope it goes away.
Old 08-30-2008, 09:16 PM
slayerized6's Avatar
i got a spec stage 1. expect some serious chatter for the first 500 miles and expect it to decrease overtime. try not to downshift a lot or let it heat up to much. start to get on the clutch after 500 miles and make it seat in.
im at 6k miles with my spec stage 1 and still get chatter. and when the clutch is warmed up after lots of city driving, it chatters like a ****
Old 08-30-2008, 10:37 PM
FNQUIKWS6's Avatar
agreed, i have the stage 2 in my ride and it chattered for at least 3500 miles. no worries, it'll eventually go away.
Quick Reply: Clutch Chatter
