The Ultimate Clutch period: The tilton triple carbon
NOW AVAILABLE!
Announcing the new, LG Motorsports Exclusive - Tilton Triple Disk Carbon Clutch for all Corvettes.
http://www.lgmotorsports.com/catalog...oducts_id=1967
This is the ultimate high performance clutch, period. Reduce rotating mass by over 48 lbs+ with this light-weight clutch. The entire clutch assembly with flywheel comes in 2 weights – 14.9 or 19.0 lbs. The performance of the carbon disks allows the car to have excellent street manners while providing the best clutch performance available for any performance package.
Don't be afraid to throw massive amounts of horsepower and torque at this clutch. The Tilton loves to be slipped. Its TRUE, 100% carbon floater discs and drive discs will not wear out like typical clutches found on the market today.
This clutch offers value that comes in the form of long life and the fact that it is delivered with 2 extra plates that compensate for wear. This contributes to the very high mileage reported by users of this clutch.
This clutch revs extremely quickly yet is very streetable. It will not squeal like ceramic or bronze clutches and can be adjusted 2 times. Pressure plate spacers can be added throughout the life of each rebuild to bring the clutch back in spec.
Extreme torque capacity and light weight for fast revs makes this the only choice for serious performance enthusiasts.
This clutch is a large street version of our American Le Mans racing clutch, built for the street and for long wear. The clutch package comes with different thickness wear plates that can be changed out through the clutch disks wear life. There have been reports in high power turbo import cars of up to 40,000 miles of extreme use.
Even after the wear plates are cycled though the package, we offer a rebuild option where the manufacturer will rebuild the clutch back to stock specs.
These features are why this clutch has great value and performance. It is clearly the best Corvette high performance clutch on the market, bar none.
IIRC, Tiago is running a Spec Super Twin... ALOT cheaper than the triple Tilton, but on full metallic discs (VERY noisy! not too friendly either)... And it still won't hold what this thing does.
You know, IIRC, I think stevieturbo is running one of these... It's the one part of his car he's never had to replace after years of non-stop beatings at the track. This thing's meant to last that's for sure.
