Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Clutch pedal stopper (limiter)
Old 08-06-2009, 01:14 PM
wrd1972's Avatar
Default Clutch pedal stopper (limiter)
Category: Accessories
Price: $80
Location (State): AL
Item Condition: Brand New
LS Engine?: Fits LS Engine
PM ME IF INTERESTED
FS:
4th gen f-body M6 adjustable clutch pedal stopper that limits the amount of pedal travel with performance clutches. If you have a performance clutch and it starts to engage many inches or even well away from the floorboard, then this pedal limiter will remove that "dead" area between the floor and the engagement point by shortening the clutch pedal travel. No more "hunting" for the sweet spot for the clutch to start to grab.
The limiter is adjustable so it can be dialed into the exact engagement point that you require.
Should not be used not with stock clutches or light performance clutches that start to grab right off the floorboard.
Installs in 5 minutes to the existing master cylinder u-bolt and includes hardware. Absolutely no modding to the car required.
This is a custom made part that you will not find anywhere else.
$80.00 shipped to 48 states.
PM ME IF INTERESTED
Old 10-12-2009, 11:00 AM
wrd1972's Avatar
daily bump
Old 01-05-2010, 08:35 AM
wrd1972's Avatar
daily bump
Old 03-30-2016, 07:35 AM
wrd1972's Avatar
Ive got a few more of these left if anyone is interested.
Old 07-27-2016, 08:44 PM
zoomo's Avatar
Bump! thanks man! i cant wait to get this thing on there and not have to hunt for the teeter point anymore
Old 07-27-2016, 10:33 PM
stanggreg90's Avatar
This work with a mcleod clutch?
Old 08-03-2016, 09:07 AM
wrd1972's Avatar
I honestly cant say. If the clutch engagement point is very high, then it should work as intended. It is NOT to be used if the engagement point is right off of the floor.
Old 08-03-2016, 10:05 AM
ramairetransam's Avatar
what the heck is this . I have a tick master cylinder why would i want something like this . I dont understand what it does.
Old 08-03-2016, 11:09 AM
brandon6.0's Avatar
Very smart idea. I noticed on alot of clutch setups its tricky to find that sweat point yo were it engages. Should help alot of 5 speed setups at the track.
Old 08-08-2016, 05:33 PM
02SOMWS6's Avatar
Free bump. ....once my clutch is dialed in I may be ordering one
Old 08-09-2016, 10:53 AM
zoomo's Avatar
Got mine in the mail yesterday. Well put together I fought with it at first, because I pulled the nuts from the master. After a while I realized you designed it to be placed on top of them easier to install that was, I was just confused ha-ha! Thanks man! Works great!!
Old 08-10-2016, 03:42 PM
wrd1972's Avatar
I will need to create a new sheet explaining that going forward. Thanks for the feedback. Yeah it installs in just a few minutes. Then you just tweak the adjuster bolt.
Old 08-13-2016, 04:00 PM
TTSSZ's Avatar
What about the switch behind the clutch that keeps the car from starting unless the clutch is pushed all the way in?
Old 08-14-2016, 10:00 PM
wrd1972's Avatar
The switch on mine is adjustable. Just have to lengthen it if need be. Or at worst, shim it a bit. That said, nobody has raised the actual concern so I will assume that the switch operational "range" was not adversely affected by those who have used it.
Old 08-15-2016, 08:32 AM
zoomo's Avatar
I have my switch zip tied closed. You can also just hook the wires together. It's actually a little bit hard on the thrust bearing to have the clutch pedal engaged while starting,especially with a heavy pressure plate. Just imagine all that force pushing the crank forward with no oil. I disable the clutch switch in any car I own.
On another note, I absolutely love this clutch stopper. Being able to adjust the engagement point helped me out a ton on taking off smoothly with this 6 puck clutch. No more hunting for the engagement point taking off from a stop light. Just push the pedal as far as it goes and it starts to engage nearly immediately when I start to raise my foot. I love it
Old 08-22-2016, 08:35 AM
wrd1972's Avatar
Here is some more info.
Clutch disks (typically stock or light performance) that have a marcel or wave spring between the linings, typically require a full length clutch pedal. The marcel spring will compress as the clutch is engaged thus the longer pedal. In these cases, the pedal limiter should NOT be needed since its likely the clutch will start to engage, right near the floor.
Now in the case with racing and performance disks that do NOT use the marcel spring. These clutches will likely always have a much shorter length clutch pedal and this is where my limiter will work its magic. Thats because there is no marcel spring to compress.
So from my experience, a NON marcel disk type clutch set-up will start to grab when the pedal has moved several inches away from the floor. The limiter simply removes that "dead" spot. Hope that helps to further clarify.
Old 07-20-2020, 05:09 PM
wrd1972's Avatar
Yearly Bump
Old 06-23-2023, 01:32 PM
Javin53's Avatar
I have a 2000 trns am . Just installed new "improved" GM master Cylinder. So everything is stock. Car only has 20,000 miles and is not driven hard. The clutch pedal is now about 1.5 inch above the brake pedal. (note it was even with brake pedal before changing master cylinder.) ( wish I would have read foram before I would have put in an adjustable MC)
The engage is up pretty high. The pedal slack is less then 1/2 inch which seems correct. . Clutch engages about 2 inches after start pedal presure so very high off floor.
Not happy with pedal height or how high pedal engages clutch. There is no slipping and am pretty sure clutch plates are in good shape.
Will your device help. Not sure exactly how it works. Can you explain further --- it would seem to me if it moves the pedal down then the clutch would be engaging..
Was thinking of putting shim in between firewall and MC. That would move pedal down and in effect lower engage point.
Any suggestion s.
Quick Reply: Clutch pedal stopper (limiter)
