What the hell is this?
Old 03-21-2010, 06:48 PM
jconk's Avatar
Default What the hell is this?
I'm pretty sure it's broken around the base cuz whatever it is it doesn't stand up straight it's wobbly and I can lift it up a fraction of an inch (feels like it's connected by a wire), when I hold it down on it's base it feels like it's pushing a metal diaphragm down cuz you can hear it click up and down. Can I just glue the shaft down to its base?
The red circle is the part, the green line is the split
BTW my car is holding an ungodly low oil pressure so I'm thinking this may have something to do with that
Old 03-21-2010, 06:49 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You just broke the oil pressure sending unit
Old 03-21-2010, 06:54 PM
Joshiedoom's Avatar
Yep, its cheap at autozone. Go pick one up and swap it out.
Old 03-21-2010, 07:02 PM
samson_420's Avatar
Cool, I learned something. . . . . Never knew that thing was back there.
Old 03-21-2010, 07:06 PM
98ZEMT's Avatar
CHEAP?! I beg your pardon sir. I paid 45 bucks for that piece of crap. AND had to drive a million miles to get one. But yes that is your OP sensor. Better get one. I think they come broke from the factory!!!
Old 03-21-2010, 07:09 PM
98PurpleT/A's Avatar
Talking
it seems that way
Old 03-21-2010, 07:26 PM
samson_420's Avatar
Damn, they are 50 Bucks. . . . Also apparently the 98's are different and use a 2 wire connector.
Old 03-21-2010, 07:40 PM
98ZEMT's Avatar
Told you. Sorry. I do hate it when I'm right. It sucks. Good luck with it. I think you need to use a wrench to remove it. I can't remember if I used a socket or not. But its not that hard to change especially since you have the intake off. Are you swapping intakes?
Old 03-21-2010, 07:48 PM
jconk's Avatar
I have an 01 so I already have the LS6 intake, I just swapped heads and cam and when I started it for the first time the oil pressure was really low so I started hunting for problems and that's what I found
Again, the actual wire isn't broken
I think I already know the answer to this-but couldn't I just glue the shaft back to the base?
Old 03-21-2010, 07:58 PM
98ZEMT's Avatar
I would say absolutely not. But see what some others have said. I really don't think that will work. Not to mention it will break again. What if the diaphragm piece inside broke? You'd be looking at a lot of oil spray and before you know it, you're sending that engine to the scrapyard and buying a new one. Is it really worth it for the 50 bucks they cost?
Old 03-21-2010, 08:48 PM
SOMbitch's Avatar
AZ, Advance etc... sells a plastic socket just for those for $6-$7.
