6.0 swap
6.0 swap
ok so i know with the ls trucks u can just swap the motor to a 6.0 with out changing the computer or wireing can i do that with my camaro the stock 5.7 has alot of miles and just looking to swap the short block... any advise?
You'll need a knock sensor harness extension and an extension for the cam sensor. I think Katech sells a kit for this purpose. You must use LS2 knock sensors. They are different between the LS1 and LS2. Other than that, I think everything else is pretty much plug and play. You'll have to use your oil pan also. If I'm forgetting anything here folks, feel free to pitch in.
