ngk tr6
ngk tr6
i know i dont really need the tr6's but i went ahead with them any way. What is the gapping for them? i have been looking online but every site has a different answer. very frustrating.
ngk site says .040 for the vpower tr6. is that the best gaping? all i have done is LTS, and off road Y for now
LS1Tech Administrator
Received 1,794 Likes
Why did you pick the TR6 for a mild NA application? Just wondering....
LS1Tech Premium Sponsor
First thing, take them back and swap for the TR55's. Then gap them around .050-.055"
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The guy who wrote my tune and does all the work at straight line speed where I live strongly suggested the TR6 over TR55. And online even for the 55's it says .040 so why .050 - .055
55's on your application will be great (no extra compression, no power adder, etc)! The wider gap is because you can! The ignition systems on these cars are very strong, and have no problem firing over that gap. You want the largest gap you can run without blowing out the spark (short answer).
__________________
Where does it say that? The TR55 comes out of the box gapped at .059". Recommended gap for the LS1 was .060 from the factory, and most people run their TR55s gapped anywhere between .050 and .060 for best results. IMO, .040 is too tight of a gap for the TR55 in an LS1.
I agree 100% with all of this.
ngk.com has a chart showing to gap it at .040 . http://www.ngk.com/more_info.asp?AAIA=1382486&pid=3686
i dont know how he is tuning the car. but why would it hurt my performance? why would a colder plug be less effective?
my car is already on jack stands while im installing the headers. Am i running that big of a risk to go out and get the TR55's?
LOL, I just pictured you in a politcal ad "I'm RPM WS6 and I approve of this message."
A cooler plug, when not needed, will not last as long and can foul prematurely. Hate to ask, but if you're so set against what we have to say, and what is fairly common knowledge amongst the members of this and other forums, then why'd you start the thread?
__________________
LOL, I just pictured you in a politcal ad "I'm RPM WS^ and I approve of this message."
Also, that link is just showing you what the gap is for that particular plug, not saying it's the best gap for your application.
I'm a bit concerned about why he would recommend a colder plug for a stock, non-power adder engine. My only guess is some very ragged edge tuning, which I am not a fan of for street cars. You need some margin of error for a car that'll be driven under varying weather and traffic conditions on pump fuel.
People with N2O still use this plug even when their finger isn't on the button, but it's just not the ideal plug for an application where a power adder (or high compression) isn't going to be used full or part time. If you're stock and always NA, you will get better results from the stock heat range plug.
