243 heads
Old 09-14-2010, 11:38 PM
brandon9598's Avatar
Default 243 heads
I've got a friend selling 243 ls6 heads with prc .650 double springs. How much more power would that produce over stock ls1 heads? Would they be able to support an ms4 cam?
Old 09-14-2010, 11:39 PM
01 WS6ICK's Avatar
id like to know 2!
Old 09-14-2010, 11:43 PM
Z28_LT1's Avatar
Are we talking ported or non ported?
I'd say a conservative guesstimate would be about 50 hp at the rear wheels, maybe less, maybe more. What cam do you plan on running with it if you do get it? How much is he willing to let them go for?
Edit: Disregard question number 2. I reread and noticed you wanted to run an ms4 cam.
Old 09-14-2010, 11:59 PM
sidewayz28's Avatar
just an FYI i made 395 rwhp on a mustang dyno with a cam... I added stock LS6 heads and a FAST 90/90 and put down 430 rwhp and close to another 45 ftlbs with those 2 items.
you'll probably pick up anywhere from 15-20 rwhp
YOU ARE NOT getting 50 rwhp with stock 243s... conservative?!?!??!
Old 09-15-2010, 01:11 AM
They are not ported. Does anyone know if those springs are all I need for the ms4 or would I have to get pushrods too? And so I can expect around 20 whp?
Old 09-15-2010, 01:16 AM
sidewayz28's Avatar
how much lift is an MS4? just over .600" lift right? Yes youre going to need hardened push rods. You should get APPROXIMATELY 15-20 rwhp with the heads.
those springs should be good to go unless their super worn out
Old 09-15-2010, 01:28 AM
BlkBird2000's Avatar
Up to 15-20 depending on what heads you have right now.
Old 09-15-2010, 02:14 AM
Bone stock ls1 heads
Old 09-15-2010, 05:28 AM
SOMbitch's Avatar
15-20 max on unported 243's. The ms4 lift is .649 IIRC so you are right at the limit.....I would pull a couple springs and check pressures... IMO that is not a very good DD cam because of the very agggressive lobes which are tough on springs, valve seats etc...
Old 09-15-2010, 06:37 AM
garygnu's Avatar
you will need better push rods,and upgrade your rocker trunnion bearings.for that cam you need a good stall and gears.big cam not= fast.
Old 09-15-2010, 12:43 PM
MonmouthCtyLS7's Avatar
you'll see about 15 rwhp
Old 09-15-2010, 08:14 PM
Z28_LT1's Avatar
That's why I was asking about the cam, but I forgot to change the number. whoops.
Old 09-16-2010, 09:22 AM
thunderstruck507's Avatar
What is the rest of the setup?
What year is the engine? If it's a 98 you might squeeze out a couple more hp. I would guess around 20 total.
Why do you think you want a ms4? If you have to ask about 243 heads I would venture to guess you have a lot of reading and learning to do rather than just sticking in one of the biggest off the shelf cams that fit and hoping for the best. If you're combo isn't right that cam will run like **** even if it does throw down high dyno numbers.
Don't forget you are going to need pushrods, ls2 timing chain, upgraded oil pump, most likely larger injectors, gaskets, fluids, and head bolts.
A dyno and street tune will be mandatory.
If you're an auto a 4000+ stall will be mandatory and deeper gears in the rear.
If you're manual you will need 4.10s minimum.
And with either you will need headers, exhaust, ls6 or better intake, and lid minimum to support the heads/cam.
Old 09-16-2010, 09:38 AM
jlink's Avatar
I just put ported 243's with stainless 2.055/ 1.57 valves on my ls1. I do have the ls6 intake and a cam, headers, intake, and exhaust. I am expecting 35 rwhp gain or so. Its going on the dyno later this evening so ill post back and let you know. But 15-20 rwhp sounds about right for stock 243's on an ls1.
Old 09-17-2010, 08:45 AM
jlink's Avatar
FINAL NUMBERS- 14 rwhp. Very disappointing. Very
Old 09-19-2010, 04:02 PM
SOMbitch's Avatar
Who did the port work??? PM me if you would rather.....
Old 09-20-2010, 08:16 AM
98z8uup's Avatar
Old 09-20-2010, 11:12 AM
sidewayz28's Avatar
guys.. a dyno is a TUNING tool..
Ive been on a dyno and made 350rwhp with a H/C/I set up. Made 430 rwhp on a dif. dyno with the same setup.
#'s don't mean anything.
Old 09-20-2010, 12:16 PM
Z06 Steve's Avatar
were the heads milled?
Old 09-20-2010, 09:55 PM
jlink's Avatar
I bought them from hutter performance. They said they were ported by C.F.E. They were milled .005 just to remove a scratch on them. I will say that before them my p/b on motor only no n20 was 12.700. After them I ran a 12.277. In addition to the heads I had put on a monster level 4 lightflywheel, solid motor mounts, and qa1 adjustable drag shocks since the 12.700. I do attribute most of the gains from the heads. 14 rwhp was depressing to see, but I was happy to be in the low 12's on motor. Should take me from high 11's on spray to low 11's. Maybe 10's by next year. Pretty good for a goat
