whats up guys!
whats up guys!
Is it a good idea to put cam and heads in an automatic 98 Z28 with 128,000 miles. I'm going to put a cam, but not sure about heads. I'm thinking its too much work for an old engine.
Second question is, if I use Mopar combustion chamber cleaner would the engine lose compression? Thanks
I was kinda wondering the same question.. I got a 2000 z28 with 117,000 and im planning on pulling the motor and tranny this winter for a H/C install. Im gona tear the motor down to clean everything and just kinda do a visual inspection on it all.
I would think as long as you dont put heads on it that will bump up the compression too much your bottom end should hold together well, i would do hardened pushrods and some good double beehive springs with the cam, and a new oil pump and timing chain.
