How to tell if your engine has a govenor?
You are saying it's odd your car didn't max out at 154MPH? The speedo only goes to 155MPH...
Anyways, I believe reading that the car is governed at about 160MPH. With no governor they can get the car up to 180MPH, top speed for the engine.
One of the SLP big shots, in the day, told me he took a WS6 to Talledega Raceway for a top speed run. The car was filled up with 94 octane and the tire pressures were increased (to allow a margin of safety against tire overheating) and a professional driver got the stock car to more than 272kph, 169mph. Actually, he claimed the car would do 172mph, but for some reason my memory of the run was him telling me "more than 272kph" . He did not mention any manipulation of the computer etc to achieve this feat. He also claimed that the Camaro would be a couple of ticks slower due to the aero of it. One of these days I'll try to clarify if I can find him...
I watched a video on youtube of several cars and their top speed runs. Video was filmed in 1997. They used a 1997 Camaro Z28 or SS, I don't remember. But it had the LT1, and it got up to about 172MPH, completely stock. I imagine the LS1 would be able to surpass that.
I do believe a previous poster stated somthing backwards.. A governor will shut your car down a limiter simply limits max rpms your able to achieve therefore limiting your speed... So umm ya.. Kinda some disinformation in here but the easiest way to fix a car stuck at 110 is buy a hand held tuner..
I remmy when I had 2001 SS come with governor throttle. When I had bad stuck on snow pavement. my SS run likely surge on gas and run TOO weak run. Something wrong w/ governor something block on my gas pedal FULLY. I cut off on cable and unplug connector and still not work. Had to go tuner to remove (ECU) on governor<<F**K
I never want to have governor on my Ls1/2 Camaros
Okay.. so maybe not the best advice?
