need help with ticking noise
Ok, I read the FAQ over at "another" site, but could not figure out the problem from my car from the FAQ. So, hear is the problem. I hear a ticking sound coming from the engine, and it get increasingle louder as I go, no necessarily faster. When I have the car in neutral and give it some revs, I don't hear it. But there is still a faint ticking coming from the car. However, when I am moving, and I step on the gas, the ticking becomes increasingly louder. Now, I have no clue what this is according to reading the FAQ, it didn't address this. Thanks
Bill
Bill
My car had symptoms similar to yours and it turned out to be a spark plug that was only gapped at .023. Re gapping properly eliminated the tick.
Are you getting a SES light? Mine would come on and off before I fixed this.
Some LS1's are prone to ticking..I would not really worry about it, unless you hear a knock! It could be a lifter tick too, which is also VERY common. Take a screw driver and put it to the valve cover. Put the handle part to your ear..kinda like a stethoscope. Try and pin point the cylender that the noise is comming from! Then you only have to check one plug too! Saves some time in diagnosis. Hope this helps!
Bill
Bill
Hope that helps.
-Mike
