LS6 valve springs ?
Old 09-16-2011, 03:40 PM
Lord_Vaders_Hawk's Avatar
Default LS6 valve springs ?
I have a a TSP 224 R 114 LSA cam on the way. So excited! Ok. Back to the topic. Can I use them with this cam? I have a blue set on the 243 heads. Have waiting to go on. And a yellow set. What's the lift? The 224 is 581 lift. S can I use one of the spring sets?
Old 09-16-2011, 03:55 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Max lift on LS6 springs is .570" (blue or yellow; same spring). I would recommend PAC 1218s (.600") or better. Give us a call if you need help selecting the correct springs.
Old 09-16-2011, 04:11 PM
That's what I thought. I need a pair. But not a super expensive set. They cheaper then 918?
Old 09-16-2011, 04:33 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Definitely get a better spring than the LS6 spring for our 224R! The LS6 spring has control issues even with stock cams after some mileage is put on them, so you definitely don't want to try that with the XER lobes on this cam!
We'd recommend the Comp 26918's!
http://www.texas-speed.com/p-415-com...set-of-16.aspx
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-16-2011, 05:51 PM
BigBirdLS1's Avatar
I have the 224R cam in my car with the PAC 1218 springs and I have no complaint with them. Comp 918's will work also any of the LS1tech sponsors will have the springs you need and can get you hooked up.
Old 09-16-2011, 08:50 PM
Yeah I'm going to look at the 918's. See what I can find.
Quick Reply: LS6 valve springs ?
