dumb thermostat question
so im buying the SSRA ram air kit and to compensate for the car running a little hotter im installing a 160 degree thermostat. im seeing thermostats on summit and jegs for 5 bucks, both 180 and 160, however for 40 bucks theres the thermostat and what looks like the housing for it. do i need the new housing or will just the thermostat do. also i live in flordia so im correct in choosing the 160 over the 180 right?
Depends on what year waterpump you have. I think 97-02 have the the thermostat and housing as 1 piece--that's the $40 one. If you have a newer waterpump the housing is separate from the thermostat so all you have to buy is the thermostat which is why it's cheaper... Not super sure on the years but I do know the new ones don't have the housing included. Maybe someone else will chime in.
LS1Tech Administrator
Received 1,509 Likes
A t-stat change won't do much without changing the fan settings. If you don't change the fans, the only time you'll notice cooler temps will be at steady speed cruising.
I like to keep the stock t-stat and just change fan settings, but I don't live in Florida.
