Cooling system question.
Hello, I am just finishing a 46 Chevy pickup truck streetrod project which has a LS1/4L60E combo from a 2000 Camaro. I am using a Griffin all aluminum radiator that was built specifically for that year truck with a LS1. My question is why does it seem that the lower radiator hose doesn't get hot? I am using a 180 degree thermostat and the fan turns on at 185 degree. The engine temp never goes over 195 degree. Do I have a problem? The people at Griffin tell me that the combination of the great cooling system in the LS1 and a very large all aluminum radiator is why the lower hose stays cool. What are your thoughts? Thanks, Al.
I am using a Dakota Digital dash with their supplied sending unit. I have no way of reading the PCM. The PCM was reset by Painless Performance to match my application.
Internet Mechanic
Do you have a diagnostic port in the harness? IMO getting a reader from like autozone will read temp that the PCM sees. Could be a case of really good cooling, and a well insulated hose.
IF I was really curious, I would test the opening temp of the thermo in a pot of boiling water and candy thermo to see when it actually opens. Then with a infered gun I would hit different spots and see what the actual temps are once the system is running and up to operating temp.
LS1Tech Administrator
Received 1,493 Likes
Like stated above, verify engine coolant temp with a PCM scanner. If it's really 195°, then I wouldn't worry about the cool hose since the engine is obviously warming up.
If you want to make it a bit warmer on average, you could bump the T-stat temp to a stock LS1 T-stat (187°F unit). You could also raise the fan on/off temps. My experience is that NA LS1s run best between about 190-210°F, so you are already in that range.
