Header install????
Header install????
Im installing LTs on my 99ss I got the driver in, having trouble removing the stock exhaust manifold on the passenger side, what do I take off???how do I remove the dip stick?
Have you pulled the plugs/wires/coilpacks first? It's the same on both sides just keep looking to see if you missed a bolt. There is a bolt you will have to get from underneath (#8 plug) for sure. There is a single (15mm?) bolt holding the dipstick tube to the cyl head, remove it and wiggle it up and out.
also i put my car on a drive on lift and did the whole install from underneath
When I installed mine, I loosened the coil pack bracket, removed the spark plug, and took out the AIR tubes. Still couldn't get the manifold off, so I took some tin snips and cut it off.
Thanks. how the hell did yall get to the bolts on the exhaust manifold with AC in the way. I couldnt even remove the coil bracket the damn AC lines were in the way. The driver side went in fairly well but I couldnt get the passenger side off!
coilpacks? wtf? when i did my headers i never touched the coils. it made no difference whatsoever. as far as the dipstick there should be a bracket holding the tube and after that just pull it out carefully. it goes in the same, its a bitch to go back in the hole but once you find it just push and it will go back in. removing the AIR tubes will help you a lot.
I recommend the O.P. remove the Coil Packs as well. It will give you more access to the Manifold Bolts as well as the 15mm Dipstick Tube Retaining Bolt.
D14HUGGER.ORANGE were you able to make anymore progress?
I only got the driver side on. The shop I work at on base is closed sunday and monday. So hopefully this thursday or friday ill get the passerger side done and get the Y pipe on. So I can start on my FAST 102mm intake manifold. Apreciate all the input guys, ill let you all know if I learn any new knowledgeable tricks.
