Crank replacement
Crank replacement
Whats up you guys I had a question in regards to replacing a stock crank. I was wondering if it needed to be balanced if I replaced just the crank. It is going to be a stock replacement for my 2000 z28.
LS1Tech Premium Sponsor
I would definitely recommend balancing! One set of rods to the next, with the same part number, can be as much as 15-20 grams difference in weight. Then you have different weights of pistons, rings, etc to factor in. ALWAYS BALANCE.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks you guys My crank bolt broke off in the crankshaft and I'm not having any luck in easeing it out. I was told to re-tap the snout and just go with it but I want to do it right. cause I'm going to be driving it pretty offten. Thanks a bunch
