Old 05-20-2016, 11:07 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
How much oil do you run in ls1 and how much is too much?
Old 06-16-2015, 09:18 AM
  #41
96aSSkicker's Avatar
A little under 6 qts
Old 06-16-2015, 11:15 AM
  #42
thunderstruck507's Avatar
minimum 6 qts
if I know I will be autox or doing a lot of hard cornering I will add a little more on top of that
Old 06-16-2015, 11:42 AM
  #43
CO_BlackHawk's Avatar
I put in the 5.75 qts right to the full mark.
Those of you bashing Fram should take a look at the Fram Ultra Guard. It really is a quality filter, and a bargain at Walmart prices.
Those of you running the longer filter, aren't you a little worried about it bottoming out, as it sticks down below the oil pan?
Old 06-21-2015, 09:08 PM
  #44
1 FMF's Avatar
if you manage to take out that 1" of oil filter sticking down, you probably have also taken out plenty of other stuff under the car.
i once didn't pay attention and put in over 7 qts, not sure how much but I was well over 1" above the full mark on dipstick and definitely noticed it when the engine was running. an oil change i usually do 6 to 6.5 qts and keep oil level not more than 1/2" over the full mark hot, measuring right after shutting engine off. that way you know the crank isn't whipping into the oil.
Quick Reply: How much oil do you run in ls1 and how much is too much?
