stick with ls1? or upgrade to newer style ls2?
Old 01-08-2012, 08:05 PM
Da Fonz's Avatar
Default stick with ls1? or upgrade to newer style ls2?
Ok, so my first post was a super success in helping me, so here we go. My question is I have a 98 z28 with 140k miles on the motor. It's gone 12.80 with a consistent time of 12.90 all day. The problem is, that I am taking this motor out to freshen it up and get her all cleaned and inspected just cause I know it is not long before i blow her sky high lol. The thing is that everyone is suggesting I step up to a ls2 while I have the motor out, seeing how all the parts are interchangeable. I know I have the old style oiling ports in my motor is that gonna hinder me in anyway? Do I just buy an ls2 short block? if so, do I need a new wiring harness or computer? or am I just an idiot overthinking this? Its gonna be mildly built cam/heads added to my previous set up. Once again, thanks for the help! everyone was extemely helpful in my first post.
Old 01-08-2012, 08:21 PM
TransAmWS.6's Avatar
Not sure about the wiring harness, but, I would definitely swap in an LS2 shortblock if you have the funds, that's definitely a solid upgrade, or even an LQ9 would also be a good option, you can get those for real good prices. And yes, you're probably going to want a new tune on the car once everything is installed.
Old 01-08-2012, 09:01 PM
Da Fonz's Avatar
Yup, planned on getting a tune due to the head/cam combo. LQ9....that's the truck block right? The iron block?
Old 01-08-2012, 09:12 PM
Ok cool, was just making sure you knew, ha. But, yeah, the LQ9 block is iron and it was in the Escalades, Silverado SS's, and a couple of the other high-end GM fullsizes, would be another very good choice and can be had for a pretty reasonable price.
Old 01-10-2012, 09:01 PM
garygnu's Avatar
it don't cost much to convert to a ls2,also get a ls6 intake and a nice cam pkg too make it worth your while.
Old 01-10-2012, 09:08 PM
S8ER95Z's Avatar
Is the ls2 vastly superior to the ls1/6?
Old 01-10-2012, 09:47 PM
^^The Intake or the motor as a whole?
Old 01-10-2012, 10:27 PM
S8ER95Z's Avatar
The motor... I see people switching just didn't see a good reason and wondered why. Thanks!
Old 01-11-2012, 03:05 PM
Da Fonz's Avatar
I have a good intake, gonna do heads/cam combo also, but do i need to get a new computer? Or just get a tune? Idk if it makes a difference. I have a 98 z28. Is there anything else I could be missing?
Old 01-11-2012, 03:24 PM
Da Fonz's Avatar
By the way, I'm switching from ls1to ls2 cause they have a bigger cylinder bore, and a different oiling system within the block. My motor right now has 140,000 time for a freshen up, so I figured may as well upgrade and keep this motor off to the side. My ls1 being pre 99 has different castings than post 99. But I will say, I have not had ONE problem with this motor! At all!!
Old 01-11-2012, 04:22 PM
777's Avatar
People switch to the ls2 because the bore size is larger = more cubic inches. You would have to at the bare minimum get ls2 pistons or new pistons with that bore size.
The only thing that is a direct swap would be an ls6 block and there's no reason to pay money for one since they are nearly identical and offer no gains.
EDIT: didn't see your post above, you already know what I said haha
Old 01-11-2012, 05:06 PM
ULTIMATEORANGESS's Avatar
Smile
i went with an ls2. i just had my heads and everything swapped over. added a FAST 102.
i think it runs strong as **** and im happy i went that way.
Old 01-12-2012, 04:26 PM
zracer323's Avatar
Texas Speed (and other companies) sell an LS2 conversion kit. You will need a different camshaft position sensor, LS2 valley cover, and knock sensor wiring harness.
Old 01-12-2012, 05:35 PM
Lockdown99ss's Avatar
Also, if you haven't already done so, get yourself an ls6 coolant crossover. Makes things cleaner
Old 01-12-2012, 09:46 PM
Da Fonz's Avatar
Thanks man! I checked em out and they everthing I would need. Nice!
Old 01-12-2012, 09:47 PM
Da Fonz's Avatar
Coolant crossover? Is that the throttle body bypass? Or something different?
Old 01-12-2012, 10:17 PM
Nah look it up on eBay. Just a coolant pipe connection the two heads up front under the tb. The tb bypass connects to it though. Look at a picture of it and it will make sense
Quick Reply: stick with ls1? or upgrade to newer style ls2?
