valve cover removal
Old 01-10-2012, 10:06 PM
2000maro's Avatar
Default valve cover removal
I know this topic has probably been beeten to death but today I had a idea of painting my valve covers and coil packs but I started doing it and I look at the pasanger side and its a cluster f*** is there a thread or anything about taking these off ?
Old 01-11-2012, 11:00 AM
dutinsss's Avatar
take coil bracket off. take valve cover off.
Old 01-11-2012, 11:34 AM
astro11271984's Avatar
get ready to get your hands cut up the last bolt close to the firewall is a pita i just left mine off last time i took it off
Old 01-11-2012, 11:36 AM
RedRocketZ28's Avatar
Should take you literally no more than 10 minutes to pull BOTH.
Old 01-13-2012, 08:53 AM
usafws6's Avatar
Hes a newbie give him a break, to the op just take your time and dont force anything.
Old 01-13-2012, 09:16 AM
Undertow74's Avatar
LS1Tech 10 Year
Yea passenger Side can be a pain if you have never done it before. It's still easy. Unplug your wires from coils and the wiring harness for the coils. Take the coil bracket bolts out, the rear is a pain but flexible ratchet wrench works the best. Then just pull all the bracket off and all the coils will come off with it. Then all you got it the valve cover bolts and there you have it.
Old 01-13-2012, 01:39 PM
Lockdown99ss's Avatar
+1 for leaving that back bolt off
Old 01-13-2012, 07:02 PM
arock24's Avatar
Thumbs down
He probably posted in the NEWBIE thread so ******** like you guys wouldn't give smartass answers like you did. If you don't have anything to educate the guy with, quit posting useless bullshit!
Old 01-13-2012, 09:09 PM
Starz T/A 17's Avatar
I've never seen a write-up on here but its a fairly simple taste. If your unsure I would just take your time, take one bolt off at a time and make some kind of note where it goes. It's really not as bad as it looks,
Old 01-14-2012, 12:51 AM
Zlow28's Avatar
id give you tips, but mines a lt1. Take lots of pictures and dont be afraid to disconnect and remove everything in the way.
Old 01-16-2012, 09:07 AM
dutinsss's Avatar
mine wasn't useless. just to the point.
Quick Reply: valve cover removal
