Air Conditioning Help Please!
So my '02 z28 is blowing out warm air but I can't get any cold air out of the a/c, what's the likely culprit? The original owner claimed it "went out" on him before delivering the car, I highly doubt that. Is it a possibility it just needs charged? What's the easiest and cheapest way to determine what I need done to it and how to get some cold air so I can beat this heat? Thanks everyone!
Well if you have to see if the system can hold a vacuum. If not, you have a leak somewhere. You'll need a vacuum pump and gauge manifold to check if it holds a vacuum. The cheapest way to check though would be to charge it, real simple, just hook up A/C pro, it has a gauge with r134a refrigerant and just follow the directions, you'll hear the compressor kick on and once it's fully charged, your a/c should work. If you get hot air again after 1 day or so, you have a leak and it will have to be fixed or you will consistently loose refrigerant.
how long did the a/c work when you got or has it never worked?
I'm asking because if it's a good size leak and you end up having to put freon every month, one it gets expensive and two since there's a leak it means that outside air can come in which has moisture, the desecant in the dryer can only soak up so much moisture till it lets moisture in the entire system which mixes with the freon and creates a corrosive chemical, which can lead to a/c line replacements, thats why its best to put the a'c system under a vacuum to boil out the moisture, if you're unsure if you have freon in the system Harbor Freight sells a freon gauge for the low side, it will tell you if there's pressure in the system, no pressure no freon, if there's pressure than you have an electrical issue or a compressor issue, a/c repairs at a shop can get expensive because most shops take advantage in the fact that you'll most likely would rather pay to get a/c than to ride in a hot car, see if you can talk to a tech in the back, some should have their own set of gauges and a vacuum pump that can do the job right for cheap, I only charge 50 to vacuum and fill the system with some a/c dye and freon, and that includes putting more freon when the leak is found,
since I've bought the car a few weeks ago it hasn't worked, I'm in Florida now and go back home to get my car next Tuesday, my dad said it just needed to be charged bc it was still blowing out air, I'll take all the info and try to figure out what's going on, I doubt it has been charged or serviced since it's '02, the car was a one owner so that's just what I'm going by. Thanks again for all the great info!
there is a whole lot more to air conditioning than just charging it up with r134a. it should be obvious that if the system has no refridgerant in it, it leaked out because there is a leak.
I have the same issue only hot air comes out and i live in phx its freaking hot here specially with leather seats i think i need a recharge or get that ac pro kit or i don't know?
