How do you reset the LOW OIL Light????
Old 04-09-2004, 04:50 AM
The Demond's Avatar
Default How do you reset the LOW OIL Light????
I have just did a oil change on my trans am with Mobil 1 10w 30 pure synthetic and I was wondering how I can make the LOW OIL Light turn off without disconnecting my battery?
Old 04-09-2004, 05:02 AM
1BADFNZ's Avatar
Low Oil or Change Oil ??
Old 04-09-2004, 05:21 AM
Z28Venom's Avatar
Low Oil: ADD some oil j/k
Change oil: Hold the trip reset button for 12 seconds. Oil change light will blink letting you know that it has been reset.
Old 04-09-2004, 03:59 PM
Copy & Paste Moderator
VIP1's Avatar
If the CHANGE OIL light is on:
* Put the key in the ON position, but dont start the engine.
* Then (like Z28Venom said) Hold in the TRIP button until the CHANGE IOL light blinks.
(This should take 10 - 15 seconds)
The reason i reiterated the steps is that the key has to be in the on position with the engine off.
--VIP1
Old 04-10-2004, 12:55 AM
The Demond's Avatar
Where is the trip button located at?
--VIP1
Old 04-10-2004, 12:59 AM
longdaddy's Avatar
i have the same prob.
button is right next to ODO i think. I held it for almost a minute and nothing happened.
that light has been on for almost a year, what the hell am i doing wrong?
key is in the last position "up", just where it will crank if i move it any further.
i tried putting key in acc, no go either. I swear it used to work before.
Old 04-10-2004, 04:36 PM
NKAWTG...N
StoleIt's Avatar
the trip button, the odometer reset, the little stick like thingy pointing out of the guage cluster. should be right next to the odometer and trip meter. you push that in, like your gonna reset the trip meter, then just hold it (as in dont let go of it for about 15 seconds).
Old 04-10-2004, 11:05 PM
VIP1's Avatar
Thats where it should be.
Yup.
If these instructions dont work there is an alternative that involves pumping the gas pedal, but I dont know that one.
--VIP1
Old 04-10-2004, 11:13 PM
TheHauntedZ28's Avatar
I've done that like 3 times already... For the CHANGE OIL just turn the key on(don't turn the car on) then step on the gas pedal 3 times. Turn the key off, wait a bit, then turn the car on. It's worked with me several times already.
Old 04-12-2004, 07:49 AM
Brandon_TA's Avatar
Thats how mine has been reset about 10-15 times already.
Old 12-11-2007, 11:47 PM
kill_machine85's Avatar
nothing like bringing up an old post!
Old 12-12-2007, 07:16 PM
WS6_Suicide_Machine's Avatar
why'd you bring it up?
Old 12-12-2007, 08:14 PM
SamhainZ28's Avatar
theres another way to do it without resetting your odo.
turn the ignition to on, and pump the gas pedal as fast as you can in under 5 seconds, and the light will turn out
Old 12-12-2007, 09:02 PM
kevin's_00ss's Avatar
and why did you bump it up?? hah
and off topic going by your sig your car seems bad ***. my dream; strocker with a manual valve bodied A3 bet is a blast to drive
Old 12-12-2007, 09:20 PM
ghardester's Avatar
Both methods work. What also works is the wacky idea of just changing the oil.
Old 12-12-2007, 11:15 PM
98Z28MASS's Avatar
Easiest method is to take a dump in the oil fill resevoir, just make sure no corn gets in there...could scuff a piston or spin a bearing.
Quick Reply: How do you reset the LOW OIL Light????
