Which cars (and what years) come with ls1/t56 from factory
Old 11-21-2012, 09:41 AM
fixate's Avatar
Default Which cars (and what years) come with ls1/t56 from factory
I've tried googling and searching all over even searched the sight.
From what I've found (although I found no evidence or reliable source to back it up) it's as follows:
98-02 trans am
98-02 z28/SS
97-04 corvette (supposedly excluding z06)
Thanks in advance for the info. I'm looking to put this combo in my Datsun 240z
Old 11-21-2012, 09:45 AM
alexus6798's Avatar
your list is correct, also 04 GT0.
Old 11-21-2012, 09:46 AM
elephantrider's Avatar
04 gto...
Old 11-21-2012, 07:10 PM
fixate's Avatar
Oh right I forgot to add that.. I'm actually bidding on one in a local auction on friday wish me luck! I hope I get it super cheap haha
Old 11-21-2012, 07:19 PM
TransAmWS.6's Avatar
Non-Z51 05-07 Corvette's also got the T56
Old 11-21-2012, 07:27 PM
TyCZ28's Avatar
didnt vettes have a rear mounted transmission????
Old 11-23-2012, 12:18 PM
T AM's Avatar
That's correct.
Old 11-24-2012, 12:18 AM
lemons12's Avatar
And an ls2... Just like th 05-06 Goats.
Ls1/t56
Old 11-24-2012, 08:10 PM
fixate's Avatar
One more question, assuming I get an LS1, harness, and ECU that was mated to an automatic trans will there be any problems?
Do I need a harness and ECU from a vehicle that came with an manual trans? If I can work around it what would it require?
Also I've found a t56 for sale but it says 'for viper'
Would there be any problems mating that to an ls1? Bell housing, shaft?
Old 11-25-2012, 02:11 AM
TyCZ28's Avatar
that wont work and the harnesses are slightly different.. best bet is to find a setup out of a 98-02 F-body... vettes wont work (transmission is in the back of the car), and the GTO's and CTS-v are more expensive T-56 to work on... some of the viper parts can be used in our t56 with modification but the viper one wont bolt up
Old 11-25-2012, 07:14 PM
fixate's Avatar
Thanks exactly what I needed to know.
I found an ls1 and t56 on craigslist but they're not from the same car. What issues might I have putting them together? (lets say z28 ls1 and trans am t56)
Am I just going to have to find a mated pair?
Old 11-25-2012, 08:40 PM
lemons12's Avatar
Within reason, all 98-02 fbody Ls1s T56s and 4l60es are the same.
Old 11-25-2012, 09:21 PM
fixate's Avatar
Thanks for the help and info
Old 11-26-2012, 07:45 PM
fixate's Avatar
Additional question: will a T56 from an LT1 bolt up to an LS1? If not what would have to be done to bolt it up (if anything can be done)?
Old 11-26-2012, 09:22 PM
Tall Guy's Avatar
I believe the input shafts are shorter on the LT1 t56's than the LS1's.
Old 11-27-2012, 12:32 AM
fixate's Avatar
Can the shaft simply be changed out?
Old 11-28-2012, 03:47 AM
TyCZ28's Avatar
imput shaft different hydraulic setup and clutch fork different bellhousing.. theres not much the same except the guts.
Old 11-30-2012, 11:44 AM
fixate's Avatar
Assuming I'm running lines custom for this swap and get a new bellhousing and swap out the input shaft and fork, would it then work?
Old 11-30-2012, 12:00 PM
R6cowboy's Avatar
Yes, if you get a T56 out of a LT1 car, you would need an LS1 bellhousing, input shaft, slave cylinder and throwout bearing. LT1 and LS1 T56 hydraulics are completely different.
Quick Reply: Which cars (and what years) come with ls1/t56 from factory
