Headers
I have installed a Spohn torque arm and have an adjustable panard bar and rear lower control arms on order, I will have them installed as well as the headers and y-pipe and wait untill the end of driving season in Manitoba , Canada to install the LG G5X3 cam and Comp valve spring kit as well as a Spec aluminum flywheel and clutch kit before I get a tune .
I was told the weak link is my rear end , a Torsen Gleason 3:73 ratio , it is a 10 bolt , if I do not do 3000 dumps with sticky tires I should be OK , but if I get stupid and blow it up , not to bother to fix it and put in a 12 bolt . What is recomended ?
It could go with street tires from a 30 roll or it might last 30 passes with DRs..
Take it easy and don't do any hard DR launches... If it goes and you have the coin to upgrade then go with a 9"... If not get a used stock rear for 300$ or so and take it easy on that one.
Very nice headers and y-pipe w/cats , I am a machinist with 32 years in aerospace , the car has a SLP muffler , what does Kooks have ? that is not too loud but still has a bit of a rumble . Working evening shift , I do not want to be a "heat score " going home .
Oil
The engine has Castrol conventional oil in it , but I am due for an oil change and want to switch to Mobile 1 , synthetic , what weight should I run in a 2001 , LS1 and how does Mobile 1 synthetic oil filters rate ?
