Convertible Top will not go back up, it went down OK
Not sure if this is the correct forum, but I'll try it.
At lunch today I lowered the top. Went to put the top back up, but it won't go back up. Also the trunk will not release from the switch inside the car. From the Key FOB it releases OK, but not from inside the car. Could it be a fuse? Anyone know which one?
What else could it be?
Thx,
Thx,
I would betcha money it's the fuses. If not then your pump may be out. . But I think it's your fuses, especially when you have a problem with your trunk release button as well.
Let us know.
Let us know.
All the fuses checked out OK, and I replaced the 2 circuit breakers. But I still have a problem. I just had Heads/Cam, Clutch, Trq Arm, and offroad pipes installed. I'm going to take it by the shop and have them check iytout. I'm hopingthey just forgot to reconnect something somewhere.
