cam swap question
cam swap question
So I ordered a 228r cam I had herd its better to switch your oils pump and timing chain at the same time was wondering what pump and chain do I hot to? Thanks for the help
you can get a ls2 timing chain from most vendors for $ 40 .you align the gears on the cam and crank dot to dot .check out ls1howto.com . did you order new spring and harden push rods also ?
if you get something like the katech c5r chain, make sure to replace the cam and crank sprockets too. they wear out together. A chain kit will come with both sprockets included which is ideal. Im just not sure if the c5r will fit with a melling pump
