Blinker problem
Blinker problem
For the past week or so my blinkers have been operating very oddly. When
I turn on th left blinker, I will blink every few seconds then go off for
about 15 seconds, both on the dash and outside. The right will work sporadically every 3-6 seconds and then stop. Is this a flasher problem? If so, where is it located so I can replace it.
FYI All bulbs are functioning otherwise.
Thanks
Thanks
Thanks
Thanks
Just kidding.
Sounds like a broken wire. Sometimes the wires in the stalk start to come apart. Just a hypothesis.
Copy & Paste Moderator
Originally Posted by technical
Recompile the kernel...
Back to the issue at hand.....
It could be a faulty wire (as technical suggested) or the flasher itself could be to blame. Do you get the same problem with the Hazards? The hazards use a separate blinker module. (left/right uses one module, hazards use another) If it is the blinker module, its hidden by the shin panel under the steering wheel. Once you remove that, you should see them.
--VIP1
Where is this at...right or left side? How does it come off?
People usaully have a hard time finding it so here's a pic I had taken a while back for another person. The stock one will not be yellow, and all you will be able to see from this angle is the clip. Napa makes a great heavy duty flasher for $10.
my panel has 1 screw next to the hatch release button...is that all that needs to come out? I dont want to break anything....
thanks for the pic...its a great help!
Should be two screws up top (one which you already got the other is on the opposite side), and then their are two bolts twards the bottom (they are like 8mm). When you take the panel out pull it on the same angle that it's mounted at because it has little tabs at the top.
