fuel pressure problems
Just brought a new fuel pump aeromotive 11109'for my Lq4 conversion. I have a sumpped tank ls2 fuel filter, my problem is that im still not getting enough pressure to keep my beast running, is there any suggestions?
Moderator
You don't mention regulator type, regulator is what
makes pressure in a return type system. The pump
purports to be capable but something has to provide
the restriction to build head.
^^^^^ That, plus pressure is important, but you should also measure the pumps volume, cause I can get a tiny fuel line to make a ton of pressure and have no volume, vs a large fuel line with the same pressure will have much more volume, there are many factors to make a good fuel system.
