Burning oil
Burning oil
2000 5.3 gmc sierra 133000km
Noticed I've been burning a little more oil then I'm comfortable with. Lost about .5L within 400km of driving after oil change. Replacing pcv valve with updated TSB one when it arrives. But I've noticed my number one spark plug has oil coming out of it from the head. Truck does not misfire drives fine and zero smoke. I know without compression tests won't be much help but what could it be, valve guides, rings? Would a catch can system help?
LS1Tech Administrator
Received 1,493 Likes
Every time I've had what looks like oil coming out of a spark plug hole (oil on spark plug threads, oil on head weeping down from hole), it's always been due to a leaking valve cover gasket. If you were blowing enough oil past the rings or valve guides to have it actually leaking out the spark plug hole, you'd see a ton of smoke coming out the exhaust and the engine wouldn't be running well. In fact, even then I doubt you'd actually see oil coming out past the plug threads.
