Best way to spend 6k on LS1
Old 06-12-2014, 03:08 PM
wsierra1993's Avatar
Default Best way to spend 6k on LS1
Im sure this has been gone over many times before but I have a 2001 ws6 pretty much stock except for a volant cai and slp full length headers and catback exhaust. Pretty soon I will have about 6 grand to spend on the car and would like to know what the best way to spend it performance wise would be (labor costs included). Its an M6 with 61k miles.
Old 06-12-2014, 03:24 PM
M4N14C's Avatar
I'd get started on a procharger build if you wanna go that route.
Otherwise 6k will get you a nice HCI car...
Old 06-12-2014, 03:35 PM
Zmg00camaross's Avatar
New rear end with suspension a good clutch and cam and intake. Then you have some more power with a clutch and rear to hold it and make it more reliable.
Old 06-12-2014, 06:13 PM
MikeWS6's Avatar
I believe the procharger kit w/ install for my car was $8,000 with parts and labor included. All the parts in my sig probably come to around $4,000 with tune.. FI is alot more expensive.
Old 06-12-2014, 09:16 PM
murphinator's Avatar
while you have that big of a chunk do the rear like zmg00 is suggesting along with torque arm , driveshaft etc.. you will/can make gains by dropping gearing and being able to more aggressively launch the car.
Everybody makes power first then has to pussyfoot around breaking the rear end , I haven't had my m6 car to the track because I know it will break the rear with bolt ons and sticky tires never mind doing heads/cam or FI and expecting to ever use that power.
If you had an auto car you would be hearing heads/cam/convertor as they don't take the same type of shock a manual does on launch/shifts
Old 06-12-2014, 11:35 PM
What kind of gains would I be looking at with just beefing up the rearend? I knew no matter what I did go with doing I couldnt get too crazy with power unless I did that. It would just be a matter of time
Old 06-13-2014, 12:59 AM
99Bluz28's Avatar
IMO, the best is to do as much of the labor yourself if you have the tools and know-how.
FYI, it's not hard to get the cost up to $1350 just for supporting parts for H/C. For heads, the Trick Flow GenX 220 Cylinder Heads (TFS-30610001) are excellent, and will give plenty of room to grow for about $1750 assembled from Summit Racing.
http://www.summitracing.com/parts/tf...0001/overview/
Old 06-13-2014, 01:17 AM
Would it be possible to do it without pulling the engine?
Old 06-13-2014, 02:17 AM
Sickness7's Avatar
The rear end? Yes
Old 06-13-2014, 04:13 AM
projectX's Avatar
I did trans build 1st then H/C and will soon do rear but just to keep it temporary happy I rebuilt the center section with gears too until I can toss a S60 in there.
Old 06-13-2014, 09:49 AM
Ha yeah I know the rearend could be done without pulling the engine. Talking about heads/cam. How reliable are the trannys?
Old 06-13-2014, 10:35 AM
What would be the best gears for primarily street/occasional strip car?
Old 06-13-2014, 12:47 PM
4.10 are a good gear, hell I run 4.56 but mine is a street strip car. Ran 4.10 back in the day and loved them for street driving hell still got 24 mpg. Also you do not have to remove the engine for heads and cam install.
Old 06-13-2014, 01:28 PM
BrntWS6's Avatar
Procharger for sure. That H/C will get boring fast and you'll be wanting more in a year or less. Either setup will require a better clutch. Keep the boost low until you can afford a new rear and don't hit it too hard off the line. A procharger install will be easier than H/C if your doing it yourself.
A new rear with a driveshaft etc an expensive bitch....budget 4k for one and anything less will be a bonus.
Old 06-13-2014, 01:42 PM
TXsilverado's Avatar
save your money, burn the car and never look back. it's a dark road you're heading down. first you'll be spending 6k on an engine just to break a transmission and rear end. another 10k to fix the trans/rear, then the engine will let go. after the engine lets go it will sit in a garage for 3 years and you'll lose interest. then your window motors will go. it's always something. put the money in the bank IMO LOL.
Old 06-13-2014, 01:55 PM
Rise of the Phoenix's Avatar
^^^^ Good stuff right there. So true.
Old 06-13-2014, 03:06 PM
If I were to stay naturally aspirated for the time being, would changing the intake to a 92mm be a wise decision?
Old 06-13-2014, 03:13 PM
Stop making sense!!! YOLO lmao
Old 06-14-2014, 10:28 PM
garygnu's Avatar
a custom cam with better heads .or use the current block and do a 383 stroker ls short block.look at some Texas Speed rotating assemblies and heads .TFS are good heads for 383s.
Old 06-14-2014, 10:58 PM
Sickness7's Avatar
That might be my plan for next summer. But I am worried on how power varies on a 383 ls1?
Quick Reply: Best way to spend 6k on LS1
