rear end brake lines ?????????????help
Old 08-27-2014, 09:38 PM
SS1998_maro's Avatar
Default rear end brake lines ?????????????help
hello i need a question answered for me so im swapping out the rear end off of my 98 Camaro for a 2002 SS rear end i was looking where the brake line goes and my old line just has one port and the new rear end has 2 im wondering if the person who had it before me either deleted the other line or if the 02 rear end is different?????
those are the pictures of the rear end where the brake lines go
thank you
Attached Thumbnails rear end brake lines ?????????????help-ess1409192755766.jpg   rear end brake lines ?????????????help-ess1409192793193.jpg
Old 08-28-2014, 02:37 PM
Fry_'s Avatar
The rear your swapping in came from a car with optimal 4 channel ABS and traction control, your car has 3 channel ABS and no traction control. Your bigger problem is going to be that your car needs a diff with a ABS sensor in the center section and the one you have has one at each wheel. It can be converted but it's not exactly a diy job.
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
Quick Reply: rear end brake lines ?????????????help
