My new 98 z28. All help and advice is welcome
#41
LS1Tech Administrator
Received 1,795 Likes
Yep, as I mentioned above as well, this is exactly correct. Often they are off by 100-200rpm or so.
Every single LS1 F-body left the factory with the above mentioned commanded idle speeds (650rpm P/N, 550rpm in gear for A4, 800rpm for M6). Unless your car has been custom tuned or has a vacuum leak/IAC issue, those are your actual idle speeds. You can't rely on the tach, you'd need a scan tool of some sort to see true idle rpm.
#42
I'll have to see
#48
reading this thread from the beginning(again to verify what's been done/mods to the car),there's nothing to tune for yet. The stuff on the right side of the list still has to be acquired/installed.
even putting a 3600-4000 stall in doesn't DEMAND a tune,some like to tune after a stall to modify the shift extensions.
handheld tuners are for the most part worthless,although they've been improving the handheld tuners' capabilities lately.
97 corvette,98 f-bod LS1s' have a lot of peculiarities in the computer that are different from the 99-02 f-bod LS1s'.
Back when I bought a handheld for my 98,hypertech was the only one available because 98s' are so different from 99-02s'. the only things it's good for is changing rear end gear ratio and radiator cooling fans on/off presets.
#49
A Frost tune is only another $100, and they work damn good. So no, don't buy some random bullshit that does nothing.
#50
#51
just want to be able to put on these mac mids ory without killing my mpg and without my car running like crap until the maf catches up
so only for the air/fuel ratio is frost my only option without paying 350$ for an actual tune
#56
Well my radiator has a tiny leak
I've plugged one hole and now there's a little bit of fluid down on the plastic again
I can't really get a good look at where it actually is
On ebay a radiator is 60$ shipped brand new
Should I just do that and learn how to put it in
Or is there any stop leaks that don't damage your car in the long run
I can drive it and I lose maybe 4-8oz
Also the fluid in it isn't Orange dexcool. I believe it's some type of green. But the fluid is almost more so brown.
Now if I do a flush do I need to remove those block plugs to get all of the crap out?
What's my best route here
Any and all help is appreciated .
