What is this..?
What is this..?
After looking at images of engine bays, I noticed my 02 Z28 has an air filter of some sort that doesn't appear to be in any vehicle pictures I've seen. This is in addition to the standard air filter. The hose its connected to loops back from the drivers side to behind the engine under the windshield towards the passenger side. From there I lose sight. Any ideas?
Thanks,
J
LS1Tech Administrator
Received 1,492 Likes
Many years ago, there weren't any aftermarket lids that had a provision for the AIR tube fitting that went into the stock air box. This is because the '98-'99 cars didn't have this tube, so when the factory change was made for model year 2000, the aftermarket lids hadn't yet caught up to the design change. So the solution was to simply use a smaller breather filter in the AIR tube.
Later, SLP introduced an air lid that included the provision and allowed the factory AIR line to be plugged directly into the air box like stock. But they also continued to offer a lid for the '98-'99 cars with a plug to block off this provision since the earlier cars didn't need it. In your picture above, you can see this block off plug on the driver's side edge of the lid. So basically what happened here is that someone put a '98-'99 lid on this car and therefore had to use the old method of a breather filter to deal with the AIR line. This isn't bad or a problem at all, nor do you need to "fix" it, it will work just fine as it did many years ago. But if you wanted to get the correct '00+ version of the lid, it would come with the proper fitting to attach that hose to the air lid and delete that filter. This would be purely cosmetic though, and only if it bothers you.
