My Air! and EGR! delete
Well after years of deciding i ordered the plates and a nice block off plug http://compare.ebay.com/like/2707215...=263602_304662 and took some pics of the progress
the plates from ws6 store
![Name: IMG_0133-1.jpg
Size: 36.9 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617078d1501350776-my-air-egr-delete-img_0133-1.jpg)
unbolt the air bolts
![Name: IMG_0134-1.jpg
Size: 45.4 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617079d1501350776-my-air-egr-delete-img_0134-1.jpg)
![Name: IMG_0135-1.jpg
Size: 53.8 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617080d1501350776-my-air-egr-delete-img_0135-1.jpg)
bolt on the plates
pass side:
![Name: IMG_0137-1.jpg
Size: 48.3 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617081d1501350776-my-air-egr-delete-img_0137-1.jpg)
Drivers:
![Name: IMG_0138-1.jpg
Size: 45.5 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617082d1501350776-my-air-egr-delete-img_0138-1.jpg)
Removed the hoses
![Name: IMG_0136-1.jpg
Size: 75.4 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617083d1501350776-my-air-egr-delete-img_0136-1.jpg)
And the clutter gone:
![Name: IMG_0147.jpg
Size: 69.5 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617084d1501350776-my-air-egr-delete-img_0147.jpg)
bolt on the plates
pass side:
Drivers:
Removed the hoses
![Name: IMG_0139-1.jpg
Size: 92.8 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617085d1501350776-my-air-egr-delete-img_0139-1.jpg)
Egr time. With plates from ws6store and the plug from ebay here is the step results
![Name: IMG_0148.jpg
Size: 66.6 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617074d1501350776-my-air-egr-delete-img_0148.jpg)
Clear of that stupid thing
![Name: IMG_0149.jpg
Size: 85.4 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617075d1501350776-my-air-egr-delete-img_0149.jpg)
plug installed
![Name: IMG_0150.jpg
Size: 43.2 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617076d1501350776-my-air-egr-delete-img_0150.jpg)
plates installed
![](http://i9.photobucket.com/albums/a100/zerokube/Trans%20am/IMG_0151.jpg)
goodbye
![Name: IMG_0153.jpg
Size: 78.3 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/617077d1501350776-my-air-egr-delete-img_0153.jpg)
i know i know my engine is filthy and rusted on some parts, headers are next and a good washing of the engine.
plug installed
plates installed
goodbye
I remember taking all that out of the 98 car I had and was suprised how big the damn thing is lol.
But thanks, this post reminded me I need to take the air pump out of the 01 car cause I just got a tune. I need those blockoffs thanks for posting that link. I know speed inc has then also.
this ine of the first things done on my ride . weight reduction and cleans up the engine bay alot . just add some breathers and delete the pcv and you are good to bling out the bay .
also makes sure oil and hot air does not come back through your throttle body and intake manifold . nothing like clean fresh air in the ls1 !
Ok *** question here. If I was to do this mod like remove the she the air pump and all the hoses and block everything off what else would I have to do? Like could I keep the stock exhaust headers on for the time being. And also think I saw s.omeone say something about a tune also cause of the codes that would POP up. And what would this do to the engine performance and stuff
For a 98 Camaro will I need anything other than this little set for !EGR and !AIR?
http://www.speedinc.com/shop-by-vehi...plate-220.html
2nd post, third picture.
The big fat tube that you can squeeze easily... cut that. Then jack up the driver's side wheel and unbolt the 2 bolts holding up the "window" to reach the AIR pump. Unbolt it's two bolts, unhook connectors, and you're done. Sorry if that was you that asked about this in another thread lol
