Right turn signal doesn't work
Hello all. I'm having problems with my right turn signal. It won't flash on the dash or signal but when I use the emergency lights the bulbs are all good. The left turn signal works perfectly. Anyone know what it could be? Any help is appreciated. Thanks.
Pull your right taillight off and then turn the blinker on. I bet it's just the bulb. Mine worked with the flashers on, but the blinker bulb wasn't lighting up when I turned it on. Should be the problem
Also check the socket inside the turn signal housing. Neither of my turn signals worked. One side just needed the socket terminal cleaned with a pencil eraser and it worked fine. The other side was completely corroded so i had to replace the entire socket, but they're around $8 at Autozone, etc.
Post back when you resolve the problem so others can learn from the solution you find.
Flasher relay
Just had this issue a few weeks ago. It's your flasher relay. Cost a few dollars at advance auto. Under the steering column panel. It's a plastic cylinder with prongs on it. Takes maybe two minutes to replace.
